Can not find location and IOSTANDARD constrains in Sgmii example designeucf
I generated sgmii IP core and then copy the source files under exmaple design directory and the generated ucf file, then run on ISE, there are errors when PAR because of on LOC and IOSTANDARD constrain.
But I Can not find location and IOSTANDARD constrains in Sgmii example ucf.
Could some one please help me with this?
Thanks!
Re: Can not find location and IOSTANDARD constrains in Sgmii example designeucf
Please post the entire ERROR message along with the board that you are using. If this is a custom board them state the part and package that you are using.
You can find the example_design.ucf in the example design floder created with the core outputs.
Satish
