DisplayPort RX Subsystem v2.1 - Core Problems - IBERT Implementation
I would like to try to integrate the IP core IBERT into my project: in another project it helped me.
But we had used it standalone, without our application.
In this case instead we would like to use it leaving our macro display port which is the problematic object.
Can we do or should we remove the video phy to do it?
Also the project with the display port can be compiled without phy video?
Thanks in advance,
Andrea
Re: DisplayPort RX Subsystem v2.1 - Core Problems - IBERT Implementation
Hi @andreac_avnet ,
The displayport Subsystem has to be used with the Video Phy. It does not makes sense to have the DP SS without the phy as this is a connectivity IP thus you need the GTs.
Why do you need to use gthe IBERT?
Did you ever consider to use the xapp1295 if you need to have debug the GTs?
Florent
