Visitor raymondxuym
Failed to set IOSTANDARD of a CLK PIN of Zynq Ultrascale +
Hi there:
I have a Zynq Ultrascale+ (xzcu102) and i was trying to make the GTH transceiver works.
The PCIe is connected to a FMC daughter card and takes the ref clk from the card.
However, the clk from the daughter card is LVDS, when I tried to set_property LVDS for the PCIe ref clk at FPGA, it returns:
[Vivado 12-1815] Setting property 'IOSTANDARD' is not allowed for GT terminals.
Beside, I cannot find the SelectIO Resources User Guide for Ultrascale+. Only Ultrascale, Spartan, Virtex6, 7 series avaliable.
When i type command get_io_standard in vivado, it seems no LVDS supported in this board. (Only LVDS_25, Sub_LVDS..)
Does anyone know how can i set the IOSTANDARD?
Tags (2)
Re: Failed to set IOSTANDARD of a CLK PIN of Zynq Ultrascale +
You don't need to set any IOSTANDARD for GT reference clock. It's fixed CML
It can be connected to LVDS by AC coupling.
GT User Guide has more details.
UG571 is the Select IO user guide for Ultrascale Architecture(it is applicable to both ultrascale and ulstrascale+ devices)
Satish
