How to switch between 100M and 1G in Tri mode ethernet mac
Hi,everyone
I explain my understanding firstly.
The PHY chip can switch to 100M or 1G correctly after Auto-Negotiation.
Then we can read the PHY status through MDIO&MDC interface to learn which link speed is in Physical Layer.
Next,based on the PHY link speed status,we can config Tri mode ethernet mac speed by value [31:30] in MAC Speed Configuration Word (0x410).
Is my understanding correct for switching between 100M and 1G in Tri mode ethernet mac?
Scholar dpaul24
Re: How to switch between 100M and 1G in Tri mode ethernet mac
@topxuxiang8,
Yes.
FPGA enthusiast!
All PMs will be ignored
Yes that is the documented way to do the speed change, see PG051 page 254 "Configuring the Ethernet MAC to the Correct Speed"
--Kim
Thanks a lot for your reply
thank you
Hi @topxuxiang8,
If your question has been answered, could you please mark the relevant post as "Accepted Solution"? So it will benefit other forum users.
Thank you!
