How to use MII interface IP from Vivado IP catalog
I want to use MII interface from vivado 2016.4 --> IP Catalog --> interfaces --> Advanced --> mii v1.0
but how to get the license to use this IP?
can someone tell me the procedure to enable this IP? and any related wrapper code and doc?
I am using ARTY board for my design.
I want to use Ethernet data from RJ45 jack --> PHY chip--> FPGA (data processing)
As of now I am trying for 10/100 M speed.
Please let me know how can I enable this mii interface IP and utilize in my design. and if any related reference design pls share.
Thank you
Silpa Pagadala.
Re: How to use MII interface IP from Vivado IP catalog
You can directly use the Ethernet lite core which supports MII interface and no need to use extra shim core.
https://www.xilinx.com/support/documentation/ip_documentation/axi_ethernetlite/v3_0/pg135-axi-ethernetlite.pdf
Satish
Do you mean you would like to use the pre-defined MII interface in your custom IP?
You can do this in IP Packager by auto inferring the MII interface shown as below: Capture.JPG
More details can be found in UG1118:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug1118-vivado-creating-packaging-custom-ip.pdf
Hope this helps!
"Don't forget to reply, kudo and accept as solution."
Thanks for the update Nanz,
Is this option is available for custom IP only?
I could not find the mentioned window in vivado directly.
PHY chip(DP83848JSQ/NOPB) is available on board. I want to interface it with FPGA (ARTIX 7 in ARTY board).
Hi Silpa,
As mentioned in my previous mode you can directly use the Axi Ethernet Lite core or temac in MII mode to interface with your PHY chip(DP83848JSQ/NOPB)  available on your board and no need to use the MII to RMII core.
Don't you need a MAC to interface with the PHY or what is your specific application/Constraint that need the MII to RMII shim instead of direct MAC core with MII interface
Satish
Thank you for response Satish.
Am new to AXI, is there any reference design for the above mentioned one?
Thanks & Regards,
Silpa
Since I am not using any processor in my design.
It is only FPGA Design.
Requirement is PHY --> FPGA interface using MII.
Scholar dpaul24
No matter what you do you must use a MAC core to analyze data received via RJ45.
<1>
If you wish to use the TEMAC (hardware evaluation license is free; the bit/stream will run for a hour or two) core just generate the TEMAC IP core with MII mode.
After it is done, in Vivado, if you right click on the core, Xilinx gives you an option to generate an example_design for the TEMAC core with MII i/f (it will be created as a separate project).
If you study this example_design CAREFULLY, you will understand how a design with MAC core having MII i/f works.
<2>
I never used the Axi Ethernet Lite coreso will not comment about it.
It is not needed!
FPGA enthusiast!
All PMs will be ignored
