Observer m@rx
How to utilize 10G Ethernet Subsystem with UDP packets
I want to use the 10G Ethernet Subsystem on a ZC706 development board for two use cases:
- sending data between two development baords
- sending data between a zc706 and an intel network card
I want to use 64bit interface width. So the si5324 jitter attenuator is configured for 156,25mhz and in first instance I wired the transceivers in loopback in quad 111.
AXI stream signals match the ones from the xilinx pattern generator. All ingoing signals are synchronous to coreclk.
Now I have the following issues/questions I did not find any solution elsewhere:
- I guess there is a minimal packet length required?
- Data arrive but only the first and the last 64 bit in single pieces. It seems something goes wrong. pcspma_status is 1. txuserready is high. Do I have to configure the ethernet subsystem from software? I ask because the AXI lite interface for status and configuration seems optional.
- What is the standard configuration in which the core runs? Does it send UDP packets?
Is there something else I am missing to run the core?
Any help is appreciated, thank you!
Scholar dpaul24
Re: How to utilize 10G Ethernet Subsystem with UDP packets
m@rx,
Ensure that the Ethernet packet lengths are min 64 Bytes in size. This is IEEE standard. Else core will drop the frames as errored frames.
I think the core sends only raw Ethernet frames.
FPGA enthusiast!
All PMs will be ignored
Observer m@rx
@dpaul24 wrote:
m@rx,
You're right. Below this size packets are dropped and not transmitted. But if it is raw ethernet frame, do I have to set a header in the axi stream or does the content not matter at all?
I guess it is a transparent interface. data in -> data out
Scholar dpaul24
m@rx,
No headers are required.
You frame source can be as simple as sending out something like <Dest MAC Addr> <Src MAC Addr> <Payload> <FCS>
FPGA enthusiast!
Observer m@rx
@dpaul24 wrote:
m@rx,
Hi @dpaul24 ,
thank you for the information. I am just wondering why I do not receive any data no matter what AXI data I send. Even in the simulation. Do you have an idea what goes wrong?
