Lwip timers: i want to make flags NO_SYS=1 to NO_SYS=0 in Lwipopts.h and use system_timeout() function in timers.h/.c file..
Hi  everyone,
       i want to enble timers in LWIP Library , in lwipopts.h NO_SYS is set to 1 i want to make it 0 and use system_timeout() function from timers.h.
i've tried in BSP setting but there's no options to make changes to timers. if somebody knows please help out .
i hope any xilinx employees will help me out to get rid of this problem.
THNKS IN ADVANCE.
 DEVDUTT.
Re: Lwip timers: i want to make flags NO_SYS=1 to NO_SYS=0 in Lwipopts.h and use system_timeout() function in timers.h/.c file..
Hi @devdutt09,
The screenshot I sent is from 2017.3 SDK.
"Don't forget to reply, kudo and accept as solution."
Hi @devdutt09,
In BSP settings, you should be able to disable the option:
HI @nanz i couldn't see the options as you shown in screen shot above , except these oprtions i can see other otions. if i want to see these options , should i re generate bsp with specific procedure?? if there procedure to follow please lemme know.
SDK version i use is :2016.2
thanks ,
regards Devdutt.
may i know in which version this option is available?? because i can't see it. in 2015.2, 2015.3, 2016.2
Hi @devdutt09,
Visitor zimou13
TCP connections now are kept on three lists, one for active connections, one for listening connections, and one for connections that are in TIME-WAIT. This greatly speeds up the fast timeout processing for sending delayed ACKs.
Hi @nanz thank you for response.
Hi @zimou13 i wanted to use LWIP  timer functions , because i am developing Real time streaming server using RTSP,RTP protocols.
as @nanz reply i got my expected answer,  and thanks for your reply. kudos.
thanks  regards
DEVDUTT
