Visitor tushar
MDIO Interfacing between TEN GIG ETH MAC and TEN GIG ETH PCS core IP
I am trying to read the PHY registers in Ten gig PCS, using MDIO transactions from Ten gig eth MAC. But the value I am reading is not right and also I am not getting the MDIO ready bit as HIGH ( reading MAC register 0x050C, the 16th bit is not getting HIGH which shows that MDIO is ready).
What should I do. Do I need to follow some specific steps for this. Please help
Re: MDIO Interfacing between TEN GIG ETH MAC and TEN GIG ETH PCS core IP
PG051 Table 2-35 describes about MDIO Ready which indicate the MDIO is enable and ready for a new transfer and the default value is 0x0.
To know if the bit is set, the user logic should do polling to the register.
Thanks and Regards
Balkrishan
Visitor tushar
I have already tried polling to the Register 0x050c bit 16th (i.e. MDIO ready) but that bit is not getting HIGH after my MDIO transaction completes.
I have written a procedure that will read the status register 0x01 of PHY, and to read this register I am polling MAC register 0x050C but since the READY bit (16th) is not getting asserted I am not able to move forward.
Can anyone please tell me on what conditions READY bit gets HIGH ?
