Visitor ya_dingus
SGMII ip core with a Spartan 6
Hello all
I am trying to implement a design for gigabit ethernet application. I have 8 bit data to/from a temac and would like to convert to serial before sending the data out. I thought the SGMII core would be perfect for this application, but it seems like implementing this core on a Spartan 6 will not work. The txdata and rxdata out is not serial and not differential. I am pretty sure this means I will need to use some other GT core to output to copper. Am I correct in saying this?
I am using ISE 14.7 and the target device is a Spartan 6. This is my first design so let me know if I am completely off base. I am open to any suggestions on how to improve. Thanks
Re: SGMII ip core with a Spartan 6
Yes your understanding is completely correct txdata and rxdata are not serial you have to use GT core(parallel to serial).
Xilinx SGMII Supports physical interface integrated device-specific transceiver interface.
Spartan-6 FPGA GTP Transceiver supports SGMII IP.
Link provided below
https://www.xilinx.com/support/documentation/ip_documentation/gig_eth_pcs_pma/v11_4/pg047-gig-eth-pcs-pma.pdf
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Link provided below
Pratap
Visitor ya_dingus
Thanks! This is what I thought. I implemented the SGMII core on a virtex7 board and that one actually included the transceiver. So I was surprised when the Spartan wasn't similar. Makes sense after looking at the user guides a bit more.
