Observer micrelrogerlo
Transceiver for 2.5G SGMII
Recently I am working on 2.5G SGMII validation using 3rd party PCS IP and transceiver from Xilinx IP generated from UltraScale FPGAs Transceivers Wizard (1.7). Although the SGMII design (PCS IP + Transceiver IP from Xilinx) is able to pass RTL simulation which includes SGMII link, auto-negotiation and packet transfer tests, the generated FPGA bit file is unable to get linkup in FPGA emulation.  (Note: We have two FPGA s connected back to back.) We have used a similar approach running on two Virtex-7 devices and it has been proven working in 2.5G SGMII link and auto-negotiation. However, we got the SGMII link issue after been upgraded to UltraScale FPGA device.
I wonder if the transceiver I configured is not correct. Could someone help to indicate what transceiver I should use to serve my purpose?
The following is the configuration data specified in UltraScale FPGAs Transceivers Wizard (1.7):
BASIC section: start from scratch: GTH :
Transmitter: 3.125; CPLL; 0; 125; Raw; 20; 20; Enable; TXOUTCLKPMA; Custom
Receiver: 3.125; CPLL; 0; 125; Raw; 20; 20; Enable; RXOUTCLKPMA; 20; Auto; AC; programmable; 800; 0; 0
Physical Resource:  GTHE3_CH: Bank: 221; Data pins:BC3, BC4, BC7, BC8
Optional Feature:  no update (use default value)
Structural Options: no update (use default value)
       Is there anything missing or wrong in Transceiver configuration shown above for supporting 2.5G SGMII?
