VHDL Simulation with Aurora - Question
Hello all,
Please find the below VHDL code snippet.
        process (user_clock)
          begin
             if rising_edge (user_clock) then
                if (rx_valid_final = '1' and tx_cntrl = "01") then
                    if ( rx_data_reg_pattern /= rx_data) then
                         err_sig_pattern <= err_sig_pattern + '1';
                   else
                        err_sig_pattern <= err_sig_pattern;
                 end if;
               end if;
            end if;
      end process;
Here is the information on the objects used in the above code.
 user_clock : in std_logic (100 mhz).
 tx_cntrl       : in std_logic_vector(1 downto 0);
 rx_data : in std_logic_vector (15 downto 0);
 signal rx_valid_final  : std_logic := '0';
 signal  rx_data_reg_pattern : std_logic_vector (15 downto 0) := x"a5a5";
 signal err_sig_pattern : std_logic_vector (7 downto 0) := x"00";
Note that rx_valid_final will become '1' after some point of time.
As per the code during the posedge of user_clock,  whenever rx_data_reg_pattern is not equal to rx_data, I expect the err_sig_pattern to increase by one.
But as per simulation ( vivado 2016.4), err_sig_pattern remains at 0. Why is that?. Please see the attached snap.
Note that rx_data comes from Aurora core.
At 16,663 ns, we are in the rising edge of user_clock, and rx_valid_final is '1', clearly rx_data_reg_pattern and rx_data doesn't match, but still err_sig_pattern wouldn't increase. Please advice.
Manoj.
Re: VHDL Simulation with Aurora - Question
Hi @manoj_xilinx,
rx_valid_final cannot be sampled by the rising_edge where the cursor is located.
rx_valid_final is sampled by the edge at approx 16670ns. And when that clock arrives, rx_data and reg_pattern are equal so there is no error, at least there is no error according to the code you wrote.
Cheers!
Avi Chami MSc
FPGA Site
Hi @manoj_xilinx,
Cheers!
Avi Chami MSc
FPGA Site
Thanks for your response @a_chami. I understood your point. Appreciate it.
Do you mind explaining  a bit more on launch and capture  flop in this scenario?. I would appreciate if you can include a diagram with launch and capture flop. I would like to see how this logic gets implemented.
Thanks for your time.
Manoj
Hi @manoj_xilinx,
I have to assume that, as you said, the launch flops are part of the Aurora core.
The receiving flops (the rx_data bus) are implemented elsewhere, I don't have all your code so I don't know where this is done. In your code snippet the rx_data bus is compared to rx_data_reg_pattern. The code snippet you've shown actually implements the register (flops) of the err_sig_pattern counter.
If you want to visualize these points better, opening the synthesized design on the schematic view might come handy.
Hope this helps,
Avi Chami MSc
FPGA Site
Thanks @a_chami. Your reply helps.
Appreciate your time.
Manoj
