Visitor shlomigadol
can't configure internal data width 20bits when the data rate is 6Gbps
I am using Vivado 13.4 for project with device virtex7-2000
i am trying to build simple transceiver with the following parameters: Linerate 6 Gpbs, refclk-300Mhz and internal/external data with 20 bits. no encoding.
When I set the line rate to 6 Gbps the data width options are:32, 40, 64, 80.
on lower frequency let's say up to 5 Gpbs, I got the options of 16, 20, 32, 40 , ....
According to your user guide I do have the option of internal data width of 20 bits when I am in 6 Gbps, so I don't know what is the problem
Can you help me? can you provide such an example to download?
Shlomi
Re: can't configure internal data width 20bits when the data rate is 6Gbps
I was able to generate the transceiver with your required settings.
Have a look at the below snapshot.
Satish
Please share the .xci file of your design to check it further
