i want to know wheather this 10GBASE_R has inbuild GTXE2 transceiver?????
HAI
I am interfacing 10GEMAC from open source to 10GBASE_R and then SFP+
i have interfaced 10GEMAC with 10GBASE_R leaving following pins dangling
txusrclk
txusrclk2
gttxreset
gtrxreset
qplllock
qplloutclk
qplloutrefclk
drp_den_i
drp_dwe
i got negitive slack ,
these pins are from transreceiver .. gtxe2 , i want to know does 10GBASE_R has inbuild transreceiver ?? i think it has but how to use to derive above pins ????
or should i have to transreceiver wizard ??? to generate these signals???
is these interface correct ??
10GEMAC ------ XGMII ------10GBASE_R ----- GTXE2----SFP+    ???
kindly let me know ,, i am confused ..
thanks and regards
AKRAM
Re: i want to know wheather this 10GBASE_R has inbuild GTXE2 transceiver?????
Yes the 10GBASE_R core use transceiver to implement the Phy functionality and no need of using the transceiver externally.
The user clocks and the resets to the transceiver are required for proper functioning of the core.
Refer PG068 and the example design generated with the core to know more about how these signals are connected.
Satish
Satish
