Participant a4speaker
problem in aurora example design
I am using vivado 2013.3 and want to do a loopback of a transceiver core on AC701 board.
I generated core with following parameters
lane width = 2 bytes
line rate = 2gbps
GT refclk = 125 MHz
dataflow mode = duplex
interface = framing
flow control = none
I generated example design and ran simulation without any modifications in code.
I ran the simulation for 90 us but  LANE_UP and CHANNEL_UP signals are not asserted.
Is there problem with example design?
Re: problem in aurora example design
In VIVADO, here is the way you could launch simulation with Modelsim.
1. Select the path for simulator in VIVADO project settings
2. run compile_simlib for the target device.
run "compile_simlib -help" for example command
The libraries will get compiled to .cache folder
3. launch Behavioral simulation in modelsim similar to the push button flow you do for XSIM
This is a known issue. The simulation time got better in 2014.1.
You need to wait till 1000 us for the channel_up in 2013.4
what ? 1000 us? xsim takes 5 minutes to draw even 100 us. SHould i wait for whole day to run sim for 1000 us?
Hi A4speaker,
I understand your concern.
This is certainly not a desired output. That is the reason why we are trying to reduce the simulation issue to a minimum possible value.
If you have a possibility, try using Modelsim. It will provide faster output when compared to XSIM simulation in this case.
Krishna
This is because SIM_RESET_SPEEDUP needed to be set to FALSE for production silicon reset requirements. Please refer to page 57 of ug482.
Srinadh
so there is no solution execpt to wait?
The problem in using modelsim is that i am new to TCL and i read somewhere that you cant simulate design in modelsim with just a click in vivado as was in ISE. I will take much time to run design in modelsim.
just for your info .... It took 4-5 hours to draw waveform till ...its 1600 us and still no channel up or lane up
and finally they come up at 1635 us after 5 hours on core i7, 8 gb ram. Totally insane :(
VIVADO----> Productivity multiplied
