Visitor hakjun
xapp1305 pl_eth_10g bsp not working.
Hello. I am using the zcu102 board. I booted Linux using pl_eth_10g.bsp in xapp1305 to run 10G Ethernet, but 10G does not work.
At first I used petalinux v2018.1, but ethernet did not work. So I used petalinux v2018.2, also did not work. I Attach the log file(Changed to v2018.1 version log to resolve the controversy.).
I proceeded to refer to the following site.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841830/PS+and+PL+based+Ethernet+in+Zynq+MPSoC#PSandPLbasedEthernetinZynqMPSoC-2.7.3PLEthernetBSPinstallation(10G)
bash> petalinux-create -t project -s ../reference/bsps/eth_10g.bsp
bash> cd pl_eth_10G/
bash> petalinux-config
# set sd card packaging
Image Packaging Configuration  --->
	Root filesystem type (SD card)  --->
	[ ] Copy final images to tftpboot
bash> petalinux-config -c kernel
# already settings (I do not change settings)
Device Drivers
	Network device support
		PHY Device support and infrastructure
			<*> Drivers for xilinx PHYs
	DMA Engine Support
		<> Xilinx AXI DMAS Engine
bash> vi project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
#already settings xxv_ethernet
/include/ "system-conf.dtsi"
&xxv_ethernet_0 {
	local-mac-address = [00 0a 35 00 00 00];
&gem3 {
	phy@c {
		reg = <0xc>;
		ti,rx-internal-delay = <0x8>;
		ti,tx-internal-delay = <0xa>;
		ti,fifo-depth = <0x1>;
		ti,rxctrl-strap-worka;
&sdhci1 {
	/delete-property/ no-1-8-v;
bash> petalinux-build
bash> cd image/linux
bash> petalinux-package --boot --fsbl zynqmp_fsbl.elf --fpga system.bit --u-boot --forc
copy BOOT.BIN, Image, system.dtb to mmcblk0p1
untar rootfs.tar.gz to mmcblk0p2
boot and setting pl_eth_10g.
bash> cat /etc/network/interfaces
# Wired or wireless interfaces
auto eth0
iface eth0 inet dhcp
allow-hotplug eth1
iface eth1 inet static
	address 10.0.0.90
	netmask 255.0.0.0
	network 10.0.0.0
	gateway 10.0.0.1
root@pl_eth_10G:~# ifup eth1
[   64.915717] INFO: rcu_sched detected stalls on CPUs/tasks:
[   64.921135] 	3-...: (1 GPs behind) idle=02a/140000000000000/0 softirq=1107/1109 fqs=2625
[   64.929286] 	(detected by 2, t=5254 jiffies, g=49, c=48, q=190)
[   64.935187] Task dump for CPU 3:
[   64.938397] ip              R  running task        0  2103   2099 0x00000002
[   64.945429] Call trace:
[   64.947866] [<ffffff8008085878>] __switch_to+0x98/0xb0
[   64.952985] [<ffffff80087e4f40>] sockfd_lookup_light+0x18/0x90
[   64.958799] [<ffffff80087e88f0>] __sys_sendmsg+0x20/0xa0
[   64.964093] [<ffffff80087e8980>] SyS_sendmsg+0x10/0x20
[   64.969213] Exception stack(0xffffff800d373ec0 to 0xffffff800d374000)
[   64.975638] 3ec0: 0000000000000003 0000007fc7c11e78 0000000000000000 0000007f992fc000
[   64.983452] 3ee0: 0000007fc7c19eb0 0000000000000004 0000000031687465 0000000031687465
[   64.991264] 3f00: 00000000000000d3 7f7f7f7f7fffffff 0101010101010101 0000000000000000
[   64.999076] 3f20: 0101010101010101 0000000000000038 0000007f991bcd98 0000007f991afd00
[   65.006888] 3f40: 0000007f99279588 0000000000475198 00000000000005db 0000000000000003
[   65.014699] 3f60: 000000005bf3e3ec 0000007fc7c1a650 0000007fc7c11e78 0000000000000000
[   65.022512] 3f80: 0000007fc7c11eb0 0000007fc7c1a660 0000000000475468 0000000000000000
[   65.030324] 3fa0: 0000000000000000 0000007fc7c11db0 0000000000443204 0000007fc7c11db0
[   65.038136] 3fc0: 0000007f992795b4 0000000080000000 0000000000000003 00000000000000d3
[   65.045948] 3fe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[   65.053760] [<ffffff80080837b0>] el0_svc_naked+0x24/0x28
But not working. Is there something I missed?
I am using ubuntu 16.04, and the partition of the SD card is as follows.
mmcblk0p1 W95 FAT32 (vfat)
mmcblk0p2 Linux (ext4)
