Equalizer SoC (Zedboard) based
Good evening to everyone... Could i have some help to build an equalizer based on 12 different filters (4 for the low frequencies, 4 for the medium frequencies and 4 for the high frequencies) ?
Participant peimann
Re: Equalizer SoC (Zedboard) based
Have you tried extracting your frequencies using FPGA and then scaling various frequency bands before "reconstructing" the modified signal?
Kind Regards,
Peimann, S. M.
Toddlers are the Storm-Troopers of the Great God Entropy.
Physics: Not Just a Good Idea, It's THE LAW.
Participant peimann
Sorry bout that, meant to write FFT, not FPGA.
Good Luck!
Kind Regards,
Peimann, S. M.
Hello Salvatore.95,
I think you are looking for help on a Zedboard, correct? This forum might not be a good place to ask about this since it deals mostly with the new Community Portal from Xilinx.
I will suggest that going to the following pages with a lot more information about Zedboards.
http://zedboard.org/ - main Zedboard page
http://zedboard.org/projects - projects on Zedboards.
http://zedboard.org/forums/zed-english-forum - and specific forum for the Zedboard
Please let me know if this helps.
Hi, if you have a SoC system and you are interested in build a LTV bank filter you can use a IIR type filters . Those filters have a low computational cost and can be easily implemented in C++. One of the main problems is the processing delay between the filters, this delay can affect the filtered signal, to solve this issue you must design your filters with a similar length
