ISE 10.1 FATAL ERROR
I installed ISE 10.1 on my windows 10, and when I tried running behavioral simulation, i got the following fatal error.
Running Fuse ...
fuse -intstyle ise -incremental -lib uni9000_ver -lib aim_ver -lib cpld_ver -lib xilinxcorelib_ver -o main_isim_beh.exe -prj main_beh.prj -top main -top glbl
Printing stacktrace...
ERROR:Simulator:798 - Unknown signal 1722 received
[0] (NdrClientCall2+0x11b1) [0x74246391]
[1] (NdrClientCall4+0x14) [0x742451d4]
[2] (DllMain+0xbd5) [0x63134555]
[3] (NPOpenEnum+0x6f) [0x631327ef]
[4] (WNetOpenEnumW+0xd7b) [0x733b3b6b]
[5] (WNetOpenEnumW+0x2c4) [0x733b30b4]
[6] (WNetOpenEnumA+0x42) [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
[7] [0x580607e]
[8] [0x580624f]
[9] [0x58064ce]
[10] [0x57f23d2]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
[7] [0x580607e]
[8] [0x580624f]
[9] [0x58064ce]
[10] [0x57f23d2]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
[0] [0x74246391]
[1] [0x742451d4]
[2] [0x63134555]
[3] [0x631327ef]
[4] [0x733b3b6b]
[5] [0x733b30b4]
[6] [0x733bdc22]
Done
Determining compilation order of HDL files
Analyzing Verilog file main.v
Analyzing Verilog file E:/Xilinx/ISE/verilog/src/glbl.v
Saving Verilog parse-tree work.main into e:/fpga/sample/isim/work/main.sdb
Saving Verilog parse-tree work.glbl into e:/fpga/sample/isim/work/glbl.sdb
Starting static elaboration
Completed static elaboration
Fuse Memory Usage: 215712 Kb
Fuse CPU Usage: 421 ms
Compiling module glbl
Compiling module main
FATAL_ERROR:Simulator:Fuse.cpp:164:$Id: Fuse.cpp,v 1.35 2007/11/07 21:25:47
sonals Exp $ - Failed to link the design Process will terminate. For
technical support on this issue, please open a WebCase with this project
attached at http://www.xilinx.com/support.
FATAL_ERROR:Simulator:Fuse.cpp:164:$Id: Fuse.cpp,v 1.35 2007/11/07 21:25:47 sonals Exp $ - Failed to link the design Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
Anybody got an idea? thanks a lot
