Visitor annranch
TCF Debug Process Terminal - no output - using Ubunto / Eclipse
My first C++ code ("hello world") using Eclipse on Raspberry Pi ZERO .
Same C++ code works just fine on Raspberry Pi 3B - different processor.
After reinstalling  TCF Agent on Zero I can Run (TCF) Configuration... BUT I do not get any outputs on "TCF Debug Process Terminal" .
This has been asked here before and I did try to implement the solution "buffering(?) " what ?
What setting on Eclipse am I missing? .
Wrong terminal / console ? I did try all available consoles. .
Any help would be appreciated.
Re: TCF Debug Process Terminal - no output - using Ubunto / Eclipse
Hello annranch,
First I am assuming you are trying this on a Xilinx board and Xilinx device.
There is another forum at Xilinx that might be better for this question and specifically there is a similar thread on the other forum. The similar thread is at:
https://forums.xilinx.com/t5/Embedded-Development-Tools/Can-t-see-Hello-World-when-using-TCF-Agent/td-p/753423
And the other forum is the Embedded-Development-Tools. You have other forum posts about TCF, that I will also be moving to better service you. This Forum is at
https://forums.xilinx.com/t5/Embedded-Development-Tools/bd-p/EDK
