Vivado HLS 2019.1 importing 2018.3 project
When I open a Vivado HLS 2018.3 project in Vivado HLS 2019.1 and run, this error is given:
Sourcing Tcl script '<project_path>/solution1/csynth.tcl'
INFO: [HLS 200-10] Opening project '<project_path>'.
ERROR: [HLS 200-70] Wrong solution format: <project_path>/solution1/solution1.aps: error "not well-formed (invalid token)" at line 1 character 0
"� <--Error-- ���������������������������������������"
while executing
"source <project_path>/solution1/csynth.tcl"
invoked from within
"hls::main <project_path>/solution1/csynth.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
Finished C synthesis.
The solution setting seems be broken and can't repared by editing the settings in the gui. The only way to resolve this is to delete the solution and create a new one.
