custom zedboard
hai there we had launched a xc7z020-1clg484 based board where my fpga device is not detected in vivado
i had checked the cable installations and device installations in vivado they are properly installed even i had reinstalled them still my device is not detecting it is showing error as
ERROR: [Labtools 27-2269] No devices detected on target localhost:3121/xilinx_tcf/Xilinx/00001b3102bf01.
Check cable connectivity and that the target board is powered up then
use the disconnect_hw_server and connect_hw_server to re-register this hardware target.
ERROR: [Common 17-39] 'refresh_hw_target' failed due to earlier errors.
where on hardware my device is showing
tck-3.3v
tms-3.3v
tdi-3.3v
tdo-3.3v
in default mode
where as when i am trying to connect through jtag platform cable usb 2 i am getting
tck-0.02
tms-0.01
tdi-0.01
tdo-3.22v
i dont know what is the problem here i am attaching the excel showing the voltage i had supplied to banks
i had gone through voltage measurements using multimeter on hardware where all are showing proper voltages to the banks
can anyone please help me resolve this issue regarding jtag
out with the scope,
do the JTAG test, follow the signals with the scope, see where they stop,
