zynq 7000 usb host qhd overlay encounter "data buffer error" which make usb controller transmit dead
i was porting tinyusb usb host code to the zynq 7000 platform , and make the usb device enumeration ,msc communicate with usb stick success
but when i use the fatfs f_write test the write feature,the data buffer error occured
and this phonomenon will occured when f_write size arbitrary and when f_write size is 512 aligned ,all works fine
here is the register status and qhd chain status log when the "data buffer error" occured
the reclainmation bit in the USBSTS register is always 1 , and the "total bytes " in the qhd overlay which catain a "data buffer error"
occured will not decrease anaymore
so i do not know why will this status occured and how to solve it ? Is it the hardware bug ?
register status
USBCMD: 0x00000b21
USBSTS: 0x0000a088
USBINTER: 0x000c0026
FRINDEX: 0x00002a1f
CTRLDSSEGMENT: 0x00000000
PERIODICBASE: 0x04cfe000
TT_CONTROL: 0x00000000
CONFIGFLAG: 0x00000001
PORTSC: 0x88001205
qhd list print (error bit is marked with bold style):
--ASYNC Head
[QH Node] 0x0x4cfe120 -->
QH 0x0x4cfe120
DWord 0: QH Horizontal Pointer 0x0x4cfe220, Type 1 , T 0
DWord 1: RL 5, C 0, MaxPckLen 8, H 1, DTC 1, EPS 2, EndPt 0,I 0, DevAddr 0
DWord 2: Mult 1,PortNum 0, HubAddr 0, C-Mask 0, S-Mask 0
DWord 3: Cur qTD Pointer 0x0x4cfe160
qTD Overlay
DWord 0: Nxt qTD Pointer 0x0x0, T 1
DWord 1: Alt Nxt qTD Pointer 0x0x20, T 1
DWord 2: DT 0, Total bytes 0, IOC 1, C_Page 0, Cerr 3, PID 1,
active 0, halted 0, buffer 0,babble err 0, xact err 0, non-hs-missed_uframe 0, non hs split stat 0, Ping err 1
DWord 3: Buffer 0: 0x0
DWord 4: Buffer 1: 0x1002
DWord 5: Buffer 2: 0x2002
DWord 6: Buffer 3: 0x3000
DWord 7: Buffer 4: 0x4000
@ Extra Info -
used 1,removing 0,pid 0,interval_ms 0,total_xferred_bytes_ms 0
p_qtd_list_head 0x0x0,p_qtd_list_tail 0x0x0
@ qtd list print -
[QH Node] 0x0x4cfe220 -->
QH 0x0x4cfe220
DWord 0: QH Horizontal Pointer 0x0x4cfe1e0, Type 1 , T 0
DWord 1: RL 5, C 0, MaxPckLen 512, H 0, DTC 0, EPS 2, EndPt 2,I 0, DevAddr 1
DWord 3: Cur qTD Pointer 0x0x4cfe280
qTD Overlay
DWord 1: Alt Nxt qTD Pointer 0x0x4000020, T 1
DWord 2: DT 1, Total bytes 512, IOC 0, C_Page 0, Cerr 3, PID 0,
active 1, halted 0, buffer 1,babble err 0, xact err 0, non-hs-missed_uframe 0, non hs split stat 0, Ping err 0
DWord 3: Buffer 0: 0x9bc399
DWord 4: Buffer 1: 0x9bd010
DWord 5: Buffer 2: 0x9be018
DWord 6: Buffer 3: 0x9bf000
DWord 7: Buffer 4: 0x9c0000
@ Extra Info -
used 1,removing 0,pid 0,interval_ms 0,total_xferred_bytes_ms 10562
p_qtd_list_head 0x0x4cfe260,p_qtd_list_tail 0x0x4cfe280
@ qtd list print -
DWord 0: Nxt qTD Pointer 0x0x4cfe280, T 0
DWord 1: Alt Nxt qTD Pointer 0x0x1f0020, T 1
DWord 2: DT 0, Total bytes 0, IOC 0, C_Page 0, Cerr 3, PID 0,
active 0, halted 0, buffer 0,babble err 0, xact err 0, non-hs-missed_uframe 0, non hs split stat 0, Ping err 0
DWord 3: Buffer 0: 0xa12048
DWord 4: Buffer 1: 0xa13000
DWord 5: Buffer 2: 0xa14000
DWord 6: Buffer 3: 0xa15000
DWord 7: Buffer 4: 0xa16000
DWord 2: DT 0, Total bytes 1024, IOC 0, C_Page 0, Cerr 3, PID 0,
active 1, halted 0, buffer 0,babble err 0, xact err 0, non-hs-missed_uframe 0, non hs split stat 0, Ping err 0
DWord 3: Buffer 0: 0x9bc199
DWord 4: Buffer 1: 0x9bd000
DWord 5: Buffer 2: 0x9be000
[QH Node] 0x0x4cfe1e0 -->
QH 0x0x4cfe1e0
DWord 0: QH Horizontal Pointer 0x0x4cfe180, Type 1 , T 0
DWord 1: RL 5, C 0, MaxPckLen 512, H 0, DTC 0, EPS 2, EndPt 1,I 0, DevAddr 1
DWord 3: Cur qTD Pointer 0x0x4cfe2a0
qTD Overlay
DWord 1: Alt Nxt qTD Pointer 0x0xd0020, T 1
DWord 2: DT 0, Total bytes 13, IOC 1, C_Page 0, Cerr 3, PID 1,
DWord 4: Buffer 1: 0xa13010
DWord 5: Buffer 2: 0xa14018
@ Extra Info -
used 1,removing 0,pid 1,interval_ms 0,total_xferred_bytes_ms 0
p_qtd_list_head 0x0x4cfe2a0,p_qtd_list_tail 0x0x4cfe2a0
@ qtd list print -
[QH Node] 0x0x4cfe180 -->
QH 0x0x4cfe180
DWord 0: QH Horizontal Pointer 0x0x4cfe120, Type 1 , T 0
DWord 1: RL 5, C 0, MaxPckLen 64, H 0, DTC 1, EPS 2, EndPt 0,I 0, DevAddr 1
DWord 3: Cur qTD Pointer 0x0x4cfe1c0
qTD Overlay
DWord 0: Nxt qTD Pointer 0x0x4cfe1c0, T 0
DWord 1: Alt Nxt qTD Pointer 0x0x10020, T 1
DWord 3: Buffer 0: 0xa12065
DWord 4: Buffer 1: 0xa13001
DWord 5: Buffer 2: 0xa1400b
@ Extra Info -
@ qtd list print -
--End
I test msc write interface with a random buffer address (total buffer size is 20KB ,and the address is assigned to qtd buffer address) and data size is 512 bytes algin (total size is 8KB limit) ,and then write the data into a fix secotor address (which i am sure is valid to write) , as result i found the data buffer error occur easily then i get some some advice that zynq 7000 usb controller has it's own DMA controller and when DMA controller do data transfer ,4 bytes align is recommanded, so i try to fix the data buffer address with random 4 bytes algin value ,all seems fine ,more stable than before as a result i found that fatfs f_write can not make sure the buffer address which transfer to the msc interface is 4 bytes algined, so i think there may be some quetions when usb controller DMA hanle a RAM space which buffer address is not 4 bytes aligned
