nunu
AMP: Petalinux with a softcore Mircoblaze
in my research I have find many different designs for a SoC, for example:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842435/Real-Time+Linux
My question is:
It is possible to use the both hard-core Arm A9 cpus of the zynq for Petalinux and one soft-core Microblaze cpu for a baremetal/freertos task with the approch of openAMP?
Best Regards
jovitac
It is possible with an IPC mechanism using only shared memory. We do not have any reference examples for this though
jovitac
