Available memory to use for RPU
I am using Petalinux 2018.3 on zcu102 and I would like to know how much available memory I have so I can edit device tree to increase the memories for RPU core 0 and 1. How is this possible?
Thank you for your time,
Thanos
Re: Available memory to use for RPU
Yes that's right. Up until 0x7ff00000 to be specific. You can also take a look at the memory node in the dts which has the ddr ranges specified.
memory {
device_type = "memory";
reg = <0x0 0x0 0x0 0x7ff00000 0x8 0x0 0x0 0x80000000>;
You are reserving memory from the lower ddr region which is 2G.
Hello jovitac,
Thank you for your reply but could be a little bit more specific? I mean which area is the lower ddr region? 0x0000_0000 until 0x8000_0000?
Thanos
memory {
Ok now it's clear. Thank you Jovitac for your time and your help
