az23
Bi-Directional RPC's between linux and r5
Hi all,
The RPC example xilinx provides from their SDK has the arm serve as the master (server) and the r5 serve as the Remote processor (client). The code for the arm I looked at is here; https://github.com/Xilinx/meta-openamp/blob/master/recipes-openamp/rpmsg-examples/rpmsg-proxy-app/proxy_app.c
Does that mean that only linux can only receive the rpc calls and the r5 can send them? Looking at the code, the arm does do a write init message to the r5 in order to start the rpc service: (line 574)
ret = write(proxy->rpmsg_proxy_fd, RPMG_INIT_MSG, sizeof(RPMG_INIT_MSG));
So, in theory you can program the r5 firmware to understand different linux write commands and therefor have bi-directional rpc send/receive functionality, would I be correct in that assessment?
Tags (4)
az23
Anyone have any more info? Perhaps I was a bit too vague.
