CobusR
FreeRTOS Echo Test Tick disabled
I used Vitis to generate a echo test OpenAMP application from the template.
It seems like this applcation somehow disables the tick for FreeRTOS. When I call xTaskGetTickCount() it always returns 1.
The effect is that if I try to add a second FreeRTOS task it never gets executed.
Any ideas where or why the the tick gets disabled?
Tags (3)
CobusR
Ok, so I've found the solution.
The globlal interrupts setup by FreeRTOS gets overwritten in helper.c of the echo test example.
The solution as discussed here https://github.com/Xilinx/embeddedsw/issues/75 is the make a few changes in helper.c
1. change
static XScuGic xInterruptController;
to
extern XScuGic xInterruptController;
 xInterruptController is already defined by FreeRTOS.
2. Change app_gic_initialize to
static int app_gic_initialize(void)
	XScuGic_Disable(&xInterruptController, IPI_IRQ_VECT_ID);
	/* Connect Interrupt ID with ISR */
	XScuGic_Connect(&xInterruptController, IPI_IRQ_VECT_ID,
			(Xil_ExceptionHandler)metal_xlnx_irq_isr,
			(void *)IPI_IRQ_VECT_ID);
	return 0;
After those change the tick count is incremented and additional tasks can run.
CobusR
1. change
to
	return 0;
