Visitor wm365
Has openAMP been in Yocto project?
I want to know if openAMP has been in other linux, for example Yocto project. I want to run open AMP in Wind River Linux (based on Yocto project).
Miles
Re: Has openAMP been in Yocto project?
check these links to start with your design
http://www.wiki.xilinx.com/Yocto
http://www.xilinx.com/products/zynq-7000/linux.htm
https://lists.yoctoproject.org/pipermail/meta-xilinx/2015-May/000984.html
Thanks and Regards
Balkrishan
Visitor wm365
Do you have detailed document to show how to build openAMP in Yocto project?
Best regards,
Miles
Sorry for the delay Miles but I'm sure you figured out this does not exist. From the Linux side it's really building remoteproc and rpmsg drivers into the kernel to some extent which is likely the easiest part other that which repo they come from.
John
Visitor josiasinacio
I would also be very interested to know about this. I've been using Yocto to build Linux, and I was wondering if wm365 or anyone else was able to sucessfully run openAMP using a Yocto build, without using PetaLinux at all.
Josias
