IPI_MASK
In the lib metal amp demo there is a line in common.h that says...
#define IPI_MASK   0x1000
Where did this 0x100 value come from please.
I could of sworn I found it one day but I cannot recall where.
aTdHvAaNnKcSe.
Re: IPI_MASK
This is the interrupt enable mask to receive IPI from RPU.
Please refer to UG1085, IPI Interrupts and Message Buffers section in Interrupts Chapter
RPU0 uses CH1 IPI
See CH1_IER register description in UG1087. Bit 8 should be enabled for RPU0. If you were using RPU1 this would be 0x200
