Independent remoteproc in OpenAMP system
We are currently working with OpenAMP in the configuration where two OS talk to each other (Petalinux and FreeRTOS on ZCU102 board). In UG1186 document there is an information on p. 21 that remotehost can run independently. However in the example Linux program remoteproc and runs it. After that there is some kind of handshake between OS and the connection is established.
We would like to have full separation between OSes with the functionality of communication between them. In such case FreeRTOS will be mainly for critical application and Linux could be less reliable (i.e. will be responsible for GUI).
My questions:
- could it be done with the OpenAMP?
- could we load and start FreeRTOS independently from Linux?
- is there some kind of guide how to do that?
- is there a chance to establish connection between OSes after resetting one of them (to notice it and to reinit connection)?
Re: Independent remoteproc in OpenAMP system
Remote host can run independently when you use RPMsg in Linux userspace. These steps are provided on page 38 (UG1186 v2018.1)
The reset/reconnect functionality is currently not available in Linux userspace. Please refer to Table 4-1 on page 43 for System Design Considerations
I see,
It seems I did not understand UG1186 correctly. Thanks for clarification.
