Observer sberner66
Linux running on APU with two RPU slaves (2)
I am aware of
https://forums.xilinx.com/t5/OpenAMP/Linux-running-on-APU-with-two-RPU-slaves/td-p/796915
and
https://forums.xilinx.com/t5/OpenAMP/Enclustra-XU1-run-2-RPU-slaves-at-the-same-time/td-p/918208
but they don't help with my problem.
I have two "hello world" applications for r5_0 and r5_1 which work fine when loaded via JTAG with SDK. However, I have no output from r5_1 when loaded with /sys/class/remoteproc/remoteproc1. r5_0 works fine.
The output in linux from remoteproc looks normal when loading r5_1, same as for r5_0.
All sections are in TCM, so memory conflicts can be ruled out ?
The device tree is pasted below, similar to UG1137, p. 245
/include/ "system-conf.dtsi"
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
rproc_0_reserved: rproc@70000000 {
no-map;
reg = <0x0 0x70000000 0x0 0x10000000>;
amba {
/* Shared memory */
shm0: shm@78000000 {
compatible = "shm_uio";
reg = <0x0 0x78000000 0x0 0x8000000>;
/* IPI device */
ipi_amp: ipi@ff340000 {
compatible = "ipi_uio";
reg = <0x0 0xff340000 0x0 0x1000>;
interrupt-parent = <&gic>;
interrupts = <0 29 4>;
power-domains {
pd_r5_0: pd_r5_0 {
#power-domain-cells = <0x0>;
pd-id = <0x7>;
pd_r5_1: pd_r5_1 {
pd-id = <0x8>;
pd_tcm_0_a: pd_tcm_0_a {
pd-id = <0xf>;
pd_tcm_0_b: pd_tcm_0_b {
pd-id = <0x10>;
pd_tcm_1_a: pd_tcm_1_a {
pd-id = <0x11>;
pd_tcm_1_b: pd_tcm_1_b {
pd-id = <0x12>;
amba {
/* firmware memory nodes */
r5_0_tcm_a: tcm@ffe00000 {
compatible = "mmio-sram";
reg = <0x0 0xFFE00000 0x0 0x10000>;
pd-handle = <&pd_tcm_0_a>;
r5_0_tcm_b: tcm@ffe20000 {
reg = <0x0 0xFFE20000 0x0 0x10000>;
pd-handle = <&pd_tcm_0_b>;
r5_1_tcm_a: tcm@ffe90000 {
reg = <0x0 0xFFE90000 0x0 0x10000>;
pd-handle = <&pd_tcm_1_a>;
r5_1_tcm_b: tcm@ffeb0000 {
reg = <0x0 0xFFEB0000 0x0 0x10000>;
pd-handle = <&pd_tcm_1_b>;
elf_ddr_0: ddr@70000000 {
reg = <0x0 0x70000000 0x0 0x2000000>;
elf_ddr_1: ddr@72000000 {
reg = <0x0 0x72000000 0x0 0x2000000>;
test_r5_0: zynqmp_r5_rproc@0 {
compatible = "xlnx,zynqmp-r5-remoteproc-1.0";
reg = <0x0 0xff9a0100 0x0 0x100>,
<0x0 0xff9a0000 0x0 0x100>;
reg-names = "rpu_base", "rpu_glbl_base";
dma-ranges;
core_conf = "split0";
srams = <&r5_0_tcm_a &r5_0_tcm_b &elf_ddr_0>;
pd-handle = <&pd_r5_0>;
test_r5_1: zynqmp_r5_rproc@1 {
reg = <0x0 0xff9a0200 0x0 0x100>,
dma-ranges;
core_conf = "split1";
srams = <&r5_1_tcm_a &r5_1_tcm_b &elf_ddr_1>;
pd-handle = <&pd_r5_1>;
&uart1 {
status = "disabled";
&ttc2 {
Observer sberner66
Re: Linux running on APU with two RPU slaves (2)
I found that bit 0 of RPU1_CFG , addr 0xff9a0200, is cleared which means that the CPU is halted.
I am able to start r5_1 by setting this bit.
Therefore, a workaround is
a) load and start r5_1 with remoteproc
b) load and start r5_0 with remoteproc
r5_0 sets the bit 0 of RPU1_CFG to start r5_1.
Question remaining is why is it not done by remoteproc ?
Which version of the tools are you using? Could you please provide your console log? Is RPMsg in userspace or kernel space?
Observer sberner66
using version 2018.3 for all tools
root@xilinx-zcu104-2018_3:~# echo hello_r5_0.elf > /sys/class/remoteproc/remoteproc0/firmware
root@xilinx-zcu104-2018_3:~# echo start > /sys/class/remoteproc/remoteproc0/state
[  120.932954] remoteproc remoteproc0: powering up ff9a0100.zynqmp_r5_rproc
[  120.940112] remoteproc remoteproc0: Booting fw image hello_r5_0.elf, size 222756
[  120.947565] zynqmp_r5_remoteproc ff9a0100.zynqmp_r5_rproc: RPU boot from TCM.
[  120.955271] remoteproc remoteproc0: remote processor ff9a0100.zynqmp_r5_rproc is now up
printing "hello world from r5_0" to other UART
root@xilinx-zcu104-2018_3:~# echo hello_r5_1.elf > /sys/class/remoteproc/remoteproc1/firmware
root@xilinx-zcu104-2018_3:~# echo start > /sys/class/remoteproc/remoteproc1/state
[  159.452936] remoteproc remoteproc1: powering up ff9a0200.zynqmp_r5_rproc
[  159.460113] remoteproc remoteproc1: Booting fw image hello_r5_1.elf, size 232976
[  159.467582] zynqmp_r5_remoteproc ff9a0200.zynqmp_r5_rproc: RPU boot from TCM.
[  159.475243] remoteproc remoteproc1: remote processor ff9a0200.zynqmp_r5_rproc is now up
no output from r5_1
RPMsg is not involved, just using remoteproc
If you are not using rpmsg, the shm and ipi_amp nodes are not needed. Is your rpu-firmware installed under /lib/firmware?
Observer sberner66
The shm and ipi_amp nodes will be needed for my application. Because this doesn't run on the 2nd r5 core, I reverted to "hello world" examples to keep it as simple as possible. Can the shm and ipi_amp nodes prevent the "hello world" app running on the 2nd r5 ? Shall I remove them ?
Yes, the elf files are in /lib/firmware
Try it without adding the shm and ipi nodes. I just ran this on a ZCU102. I just removed the ipi and shm nodes from the device-tree that you shared
Observer sberner66
same result
new device tree below
reserved-memory {
#size-cells = <2>;
ranges;
no-map;
power-domains {
pd_r5_0: pd_r5_0 {
pd-id = <0x7>;
pd_r5_1: pd_r5_1 {
pd-id = <0x8>;
pd-id = <0xf>;
pd-id = <0x10>;
pd-id = <0x11>;
pd-id = <0x12>;
amba {
dma-ranges;
dma-ranges;
&uart1 {
&ttc2 {
root@xilinx-zcu104-2018_3:~# ls -l /sys/bus/platform/devices/
total 0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 70000000.ddr -> ../../../devices/platform/amba/70000000.ddr
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 72000000.ddr -> ../../../devices/platform/amba/72000000.ddr
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 Fixed MDIO bus.0 -> ../../../devices/platform/Fixed MDIO bus.0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 alarmtimer -> ../../../devices/platform/alarmtimer
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 amba -> ../../../devices/platform/amba
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 amba_apu@0 -> ../../../devices/platform/amba_apu@0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 clk -> ../../../devices/platform/clk
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 cpu_opp_table -> ../../../devices/platform/cpu_opp_table
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 cpufreq-dt -> ../../../devices/platform/cpufreq-dt
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 edac -> ../../../devices/platform/edac
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd070000.memory-controller -> ../../../devices/platform/amba/fd070000.memory-controller
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd0c0000.ahci -> ../../../devices/platform/amba/fd0c0000.ahci
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd400000.zynqmp_phy -> ../../../devices/platform/amba/fd400000.zynqmp_phy
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4a0000.zynqmp-display -> ../../../devices/platform/amba/fd4a0000.zynqmp-display
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4a0000.zynqmp-display:zynqmp_dp_snd_card -> ../../../devices/platform/amba/fd4a0000.zynqmpd
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0 -> ../../../devices/platform/amba/fd4a0000.zynq0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4a0000.zynqmp-display:zynqmp_dp_snd_pcm0 -> ../../../devices/platform/amba/fd4a0000.zynqmp0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4a0000.zynqmp-display:zynqmp_dp_snd_pcm1 -> ../../../devices/platform/amba/fd4a0000.zynqmp1
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4b0000.gpu -> ../../../devices/platform/amba/fd4b0000.gpu
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4c0000.dma -> ../../../devices/platform/amba/fd4c0000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd4d0000.watchdog -> ../../../devices/platform/amba/fd4d0000.watchdog
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd500000.dma -> ../../../devices/platform/amba/fd500000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd510000.dma -> ../../../devices/platform/amba/fd510000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd520000.dma -> ../../../devices/platform/amba/fd520000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd530000.dma -> ../../../devices/platform/amba/fd530000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd540000.dma -> ../../../devices/platform/amba/fd540000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd550000.dma -> ../../../devices/platform/amba/fd550000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd560000.dma -> ../../../devices/platform/amba/fd560000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd570000.dma -> ../../../devices/platform/amba/fd570000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd6e0000.cci -> ../../../devices/platform/amba/fd6e0000.cci
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fd6e9000.pmu -> ../../../devices/platform/amba/fd6e0000.cci/fd6e9000.pmu
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fe200000.dwc3 -> ../../../devices/platform/amba/ff9d0000.usb0/fe200000.dwc3
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff000000.serial -> ../../../devices/platform/amba/ff000000.serial
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff030000.i2c -> ../../../devices/platform/amba/ff030000.i2c
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff070000.can -> ../../../devices/platform/amba/ff070000.can
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff0a0000.gpio -> ../../../devices/platform/amba/ff0a0000.gpio
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff0e0000.ethernet -> ../../../devices/platform/amba/ff0e0000.ethernet
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff0f0000.spi -> ../../../devices/platform/amba/ff0f0000.spi
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff150000.watchdog -> ../../../devices/platform/amba/ff150000.watchdog
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff170000.mmc -> ../../../devices/platform/amba/ff170000.mmc
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff180000.pinctrl -> ../../../devices/platform/amba/ff180000.pinctrl
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff960000.memory-controller -> ../../../devices/platform/amba/ff960000.memory-controller
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff9905c0.mailbox -> ../../../devices/platform/ff9905c0.mailbox
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff9a0100.zynqmp_r5_rproc -> ../../../devices/platform/amba/ff9a0100.zynqmp_r5_rproc
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff9a0200.zynqmp_r5_rproc -> ../../../devices/platform/amba/ff9a0200.zynqmp_r5_rproc
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ff9d0000.usb0 -> ../../../devices/platform/amba/ff9d0000.usb0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffa00000.perf-monitor -> ../../../devices/platform/amba/ffa00000.perf-monitor
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffa50000.ams -> ../../../devices/platform/amba/ffa50000.ams
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffa60000.rtc -> ../../../devices/platform/amba/ffa60000.rtc
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffa80000.dma -> ../../../devices/platform/amba/ffa80000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffa90000.dma -> ../../../devices/platform/amba/ffa90000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffaa0000.dma -> ../../../devices/platform/amba/ffaa0000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffab0000.dma -> ../../../devices/platform/amba/ffab0000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffac0000.dma -> ../../../devices/platform/amba/ffac0000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffad0000.dma -> ../../../devices/platform/amba/ffad0000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffae0000.dma -> ../../../devices/platform/amba/ffae0000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffaf0000.dma -> ../../../devices/platform/amba/ffaf0000.dma
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffe00000.tcm -> ../../../devices/platform/amba/ffe00000.tcm
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffe20000.tcm -> ../../../devices/platform/amba/ffe20000.tcm
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffe90000.tcm -> ../../../devices/platform/amba/ffe90000.tcm
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 ffeb0000.tcm -> ../../../devices/platform/amba/ffeb0000.tcm
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 fpga-full -> ../../../devices/platform/fpga-full
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 nvmem_firmware -> ../../../devices/platform/nvmem_firmware
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 pcap -> ../../../devices/platform/pcap
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 pmu -> ../../../devices/platform/pmu
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 power-domains -> ../../../devices/platform/power-domains
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 psci -> ../../../devices/platform/psci
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 reg-dummy -> ../../../devices/platform/reg-dummy
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 regulatory.0 -> ../../../devices/platform/regulatory.0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 reset-controller -> ../../../devices/platform/reset-controller
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 serial8250 -> ../../../devices/platform/serial8250
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 sha384 -> ../../../devices/platform/sha384
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 snd-soc-dummy -> ../../../devices/platform/snd-soc-dummy
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 timer -> ../../../devices/platform/timer
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 xhci-hcd.0.auto -> ../../../devices/platform/amba/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 xlnx-drm.0 -> ../../../devices/platform/amba/fd4a0000.zynqmp-display/xlnx-drm.0
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 zynqmp-power -> ../../../devices/platform/zynqmp-power
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 zynqmp_aes -> ../../../devices/platform/zynqmp_aes
lrwxrwxrwx    1 root     root             0 Jan 21 20:00 zynqmp_rsa -> ../../../devices/platform/zynqmp_rsa
You have modified your bsp settings for r5-1 output to appear on uart-1 right? Can you check if have the baud rate set to 115200
Observer sberner66
I am not doing any UART initialization in the hello world program. Because r5_0 can print to UART_1, I assume it has the correct settings by default and r5_1 should be able to print too.
I changed back to UART_0 to rule out any problem with UART_1, but the result is the same.
Observer sberner66
Added some test code in boot.S to toggle some pins,
/* this initializes the various processor modes */
_prestart:
_boot:
    ldr r0, =XPAR_MYIP_0_S00_AXI_BASEADDR
    ldr r1, =0x55555555
    str r1, [r0]
OKToRun:
/* Initialize processor registers to 0 */
	mov	r0,#0
	mov	r1,#0
	mov	r2,#0
In r5_0 the pins toggle as expected, nothing happens with r5_1, means the CPU never gets there. Seems the binary is not loaded correctly ?
Observer sberner66
I used the working processor r5_0 to print out the first words of all TCMs. The content is the same for r5_0 and r5_1.
Seems to me the reset for r5_1 is not released. How is the release of the reset controlled ?
#define r5_0_tcm_a 0xffe00000
#define r5_0_tcm_b 0xffe20000
#define r5_1_tcm_a 0xffe90000
#define r5_1_tcm_b 0xffeb0000
#define MAX 20
int main()
    init_platform();
    int i, addr;
    addr = r5_0_tcm_a;
    xil_printf("\r\nr5_0_tcm_a:\r\n");
    for(i=0; i < MAX; i++)
	xil_printf("%x\r\n", *((int *)addr));
	addr +=4;
    xil_printf("\r\n");
    addr = r5_0_tcm_b;
    xil_printf("r5_0_tcm_b:\r\n");
	addr +=4;
    xil_printf("\r\n");
    addr = r5_1_tcm_a;
    xil_printf("r5_1_tcm_a:\r\n");
	addr +=4;
    xil_printf("\r\n");
    addr = r5_1_tcm_b;
    xil_printf("r5_1_tcm_b:\r\n");
	addr +=4;
    xil_printf("\r\n");
r5_0_tcm_a:
E59FF018
E59FF018
E59FF018
E59FF018
E59FF018
E320F000
E59FF014
E59FF014
3C
1674
1690
16D0
16B4
162C
1664
E59F026C
E59F126C
E5801000
E3A00000
E3A01000
r5_0_tcm_b:
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
r5_1_tcm_a:
E59FF018
E59FF018
E59FF018
E59FF018
E59FF018
E320F000
E59FF014
E59FF014
3C
E38
E54
E94
E78
DF0
E28
E59F026C
E59F126C
E5801000
E3A00000
E3A01000
r5_1_tcm_b:
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Observer sberner66
