Openamp Demo - understanding rpmsg and mailbox/shared memory
Hello!
The OpenAMP demo requires these nodes in the devicetree: shared memory and zynqmp-ipi with mailbox.
I can see, that the baremetal demo for Cortex R5 uses shared memory, but are the mailboxes used by this code?
Does the Linux side use the mailbox along with shared memory, or just one of them? It seems to me like only the shared memory is used. The baremetal part for Cortex R5 does not even know the addresses of the four mailbox regions.
I am using latest tools, xsdk 2019.1 and everything works, I just do not understand which part of software uses the four regions of mailbox.
Thanks for help.
Re: Openamp Demo - understanding rpmsg and mailbox/shared memory
The mailbox functionality is explained here
https://github.com/Xilinx/linux-xlnx/blob/master/Documentation/devicetree/bindings/mailbox/xlnx%2Czynqmp-ipi-mailbox.txt
Mailboxes are used by the remoteproc driver
The setup of mailboxes for R5 takes place here
https://github.com/Xilinx/linux-xlnx/blob/xilinx-v2019.1/drivers/remoteproc/zynqmp_r5_remoteproc.c#L704
