kvkhekale
Openamp: Remoteproc Unable to handle kernel paging request
Hello all,
 I am trying to dual boot Xilinx-7000 CPU on CoraZ7-10 board with Linux on one Core, while bare metal application on RPU.
I have prepared bit file, hdf files from Vivado and SDK 2017.4.
According to ug-1186, I have also changed the BSP settings to include Openamp library and made -DUSE_AMP=1.
BOOT.bin and Image.ub are made from petaLinux. I can boot Linux from BOOT.BIN  and Image.ub
But following message shows up while booting, regarding remoteproc.
(Boot Sequence:)
Boot sequenceBoot sequence
Above image is about the boot sequence of Linux on  Zynq-7000.
"Direct Firmware Load for rproc-remoteproc@0-fw failed with error -2"
Is this causing the error further? What Can I do to load the firmware successfully?
Error OccurenceError Occurence
Also, regarding the above error, am I doing something wrong in setting up device tree?
 Attaching the device tree herewith this question:
jovitac
Your device-tree looks good. Could you please attach your linker script as well?
kvkhekale
Sure. Attaching linker script, rsc_table.c  and rsc_table.h files.
jovitac
Are you trying the demo application or is this your own custom application? What is the size of your rpu-firmware? Can you try with the demo app?
Also have the ddr address as 0x00400000 in your lscript.ld
Hi kvkhekale,
I have exactly the same problem.
Have you found a solution to that problem?
Best,
guelermus
Did you able to solve this issue.  I am also facing the same kernel paging issue.
Able to run built-in  baremetal echontest app on zc706 board.  Working fine.
At that same time same application throwing  this kernel paging issue on custom board.
Any suggestion to solve this issue
My target board were Zedboard and ZC706.
With Zedboard it didint work using SDK 2018.1-3.
Wit ZC706, it didint work using SDK 2018.1 well (some run-time problems).
The only working configuration was ZC706 using SDK 2018.3
Still I have no idea, how the official examples of Xilinx SDK are failed.
