Visitor hebin1124
Problem using UART0 on zedboard with amp system(linux&freeRTOS)
I want to use uart0 on cpu1 which run FreeRTOS, and it works fine with cpu0 running bare-metal app.
But, when I run linux on cpu0, neither FreeRTOS nor linux can access registers of uart0. For example:
2016-06-28 19:31:19屏幕截图.png
as you can see, I write value 0x114 to Control_reg0 of uart0, as i read it, it still 0. It also happens with my code,:
2016-06-28 19:36:37屏幕截图.png
here is the print of my code:
2016-06-28 19:38:07屏幕截图.png
BTW, at first time, I can't access the register too with cpu0 running bare-metal, but after i regenerate the fsbl with new hdf file, everything goes right. However, it still not works with linux, do I miss something?
Any help is highly appreciated.
Re: Problem using UART0 on zedboard with amp system(linux&freeRTOS)
Linux is probably controlling uart0. Remove uart0 from the devicetree.
When running an AMP configuration with Linux on CPU0 and an RTOS on CPU1, is removing a peripheral from the device tree the proper way to tell Linux to give up control of a peripheral so that CPU1 can use it?  Or is it to use one of the following?
ps7_i2c_0: ps7-i2c@e0004000 { compatible = "invalid"; };
ps7_i2c_0: ps7-i2c@e0004000 { status = "disabled"; };
/delete-node/ &ps7_i2c_0;
And is there another way to prevent Linux from turning off the clock for the peripheral, aside from kernel parameter "clk_ignore_unused", which seems like the shotgun approach to do this?
Visitor hebin1124
Thank you for your reply, I have resolved this problem. I found removing uart0 from devicetree is not  enough, because somewhere in linux kernel initialize UART_CLK_CTRL and APER_CLK_CTRL register, and it close the clock of uart0, that is why I can't access the registers.
Visitor moons520
I have the same problem,how to resolve this problem?
Thank u very much.
