Visitor maxrogozh
RPMSG reinitialization
  Hello! I have a question about reinitializing rpmsg on a RPU.  I successfully launched the standard echo_test example on the zynq-7000 platform. The libmetal rpmsg is initialized via remote application running on cpu1. I can access rmsg channel under linux(running on cpu0) using character device /dev/rpmsg0 created by rpmsg_user_dev_driver. When the symbol device /dev/rpmsg0 is closed, rpmsg_user_dev_driver sends to the remote kernel the SHUTDOWN_MSG message, after which the remote application terminates its work and destroys the rpmsg channel.  I want to modify RPU firmware in such a way, that when the character device /dev/rpmsg0 is closed, the remote application does not finish its work and does not destroy the rpmsg channel. (I mean that  I would like remote application was still working with active rpmsg channel).
  But I do not know how to do it correctly.
  The first thought was to comment out the processing logic of SHUTDOWN_MSG, but this did not result in success:
after several cycles of opening/closing of /dev /rpmsg0, the rpmsg_user_dev_driver module gives an error "unable to handle kernel paging request"
  The next thought was to destroy and re-create the rpmsg channel on the remote core. The sample code is below.
 *  Application
int app(struct hil_proc *hproc)
	int status = 0;
	reInitLabel:
	/* Initialize RPMSG framework */
	LPRINTF("Try to init remoteproc resource\n");
	status = remoteproc_resource_init(&rsc_info, hproc,
				     rpmsg_channel_created,
				     rpmsg_channel_deleted, rpmsg_read_cb,
				     &proc, 0);
	if (RPROC_SUCCESS != status) {
		LPERROR("Failed  to initialize remoteproc resource.\n");
		return -1;
	LPRINTF("Init remoteproc resource succeeded\n");
	hil_set_vdev_rst_cb(hproc, 0, virtio_rst_cb);
	LPRINTF("Waiting for events...\n");
	/* Stay in data processing loop until we receive a 'shutdown' message */
	while (1) {
		hil_poll(proc->proc, 0);
		/* we got a shutdown request, exit */
		if (evt_chnl_deleted) {
			break;
		if (evt_virtio_rst) {
			/* vring rst callback, reset rpmsg */
			LPRINTF("De-initializing RPMsg\n");
			rpmsg_deinit(proc->rdev);
			proc->rdev = NULL;
			LPRINTF("Reinitializing RPMsg\n");
			status = rpmsg_init(hproc, &proc->rdev,
					    rpmsg_read_cb,
					    1);
			if (status != RPROC_SUCCESS) {
				LPERROR("Reinit RPMsg failed\n");
				break;
			LPRINTF("Reinit RPMsg succeeded\n");
			evt_chnl_deleted=0;
			evt_virtio_rst = 0;
	proc->rdev = NULL;
	/* disable interrupts and free resources */
	LPRINTF("De-initializating remoteproc resource\n");
	remoteproc_resource_deinit(proc);
	hil_delete_proc(hproc);
	/* Re-create proc instance */
	unsigned int proc_id = 0;
	hproc = platform_create_proc(proc_id);
	evt_chnl_deleted=0;
	evt_virtio_rst = 0;
	goto reInitLabel:
	return 0;
  The problem is that after remoteproc is reinitialized, the callback rpmsg_read_cb is immediately called with the SHUTDOWN_MSG message (even if rpmsg_user_dev_driver on Linux was unloaded), and remoteproc and rpmsg instances are removed immediately after reinitialization.
I will be glad to any help. Thanks.
