RPU Device Tree Entry
In the OpenAMP 2018.1 wiki there is this line in a dtsi example...
 test_r50: zynqmp_r5_rproc@0 {
            compatible = "xlnx,zynqmp-r5-remoteproc-1.0";
            reg = <0x0 0xff9a0100 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>;
My question is, where did these (in red) numbers come from and how do I decode them please?
aTdHvAaNnKcSe
Re: RPU Device Tree Entry
0xFF9A0100 is the rpu0 cfg register
0xFF9A0000 is the rpu_glb_cntl register
0xFF340000 is the CH7_TRIG IPI register. This is used because the default APU IPI is being used for atf and pmufw.
These registers are also described in the reg-names in the node description
reg = <0x0 0xff9a0100 0x0 0x100>,
 <0x0 0xff340000 0x0 0x100>,
 <0x0 0xff9a0000 0x0 0x100>;
 reg-names = "rpu_base", "ipi", "rpu_glbl_base";
Please see UG1087 for detailed register descriptions
Ah... okay, I get it now.
reg = <>
I get that the second value is the register address now.  ;)
So what are the other three value please that are inside the <> along with the register address?
In this example the register address is always preceded by 0x0, and is always followed by 0x0 0x100.
This is 64-bit addressing. Please see reg property in the device-tree specification doc
https://www.devicetree.org/downloads/devicetree-specification-v0.1-20160524.pdf
You can also see How addressing works section in this link
https://elinux.org/Device_Tree_Usage#How_Addressing_Works
0x0 0xff9a0100 - This denotes the base address
0 0x100 - This denotes the length
Thanks jovitac, I will look these over
