frolando
SDK 2019.1 - OpenAMP echo test on R0 - ERROR: Failed to create endpoint.
Hi!,
I'm going to configure the echo test firmware (baremetal) for ZynqMP R0.
I've create the the demo example form wizard make this changes:
1. Changed RING_TX and RING_RX on rsc_table.c
2. Checked size of psu_ddr_S_AXI_BASEADDR on ldscript
2. Added .resource_table 0x3ed20000 to lscript.ld
Build the example and run it with remote proc and it fail to create the endpoint:
 echo echo_test_baremetal.elf > /sys/class/remoteproc/remoteproc0/firmware
# echo start > /sys/class/remoteproc/remoteproc0/state
[  510.745729] remoteproc remoteproc0: powering up ff9a0100.zynqmp_r5_rproc
[  510.753824] remoteproc remoteproc0: Booting fw image echo_test_baremetal.elf, size 811876
[  510.762400] zynqmp_r5_remoteproc ff9a0100.zynqmp_r5_rproc: RPU boot from TCM.
Starting application...
                       Initialize remoteproc successfully.
creating remoteproc virtio
initializing rpmsg shared buffer pool
initializing rpmsg vdev
Try to create rpmsg endpoint.
                                                              Stopping application...
        [  510.770619] virtio_rpmsg_bus virtio0: rpmsg host is online
[  510.798654] remoteproc remoteproc0: registered virtio0 (type 7)
[  510.804514] remoteproc remoteproc0: remote processor ff9a0100.zynqmp_r5_rproc is now up
What's wrong?
Thanks in advance!
jovitac
Please use the 2019.1 user guide here
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1186-zynq-openamp-gsg.pdf
You don't to change the RING_TX and RING_RX. You can use the default template that is there in SDK
frolando
Ok, today I'll trying without any changes. Thanks!
About the link of the user guide: it's exactly where i found the changes to make:
jovitac
Do you want to run the OpenAMP example with RPMsg in Linux userspace?
I assumed you were talking about kernel space because you were using remoteproc to load the firmware.
If you are in userspace, you will need to package you elf in a bif as shown in the document (on page 45) and rpu firmware will get loaded by fsbl.
I've attached the lscript.ld, rsc_table.c and bif files for your reference
frolando
Hi jovitac,
thank for your suggestion, today I'll going to make some tests.
We would like to use the user space approach but deployng our R5 firmware with remoteproc, isn't possible?
Thanks!
kdpatinos
Did You solve your issue?
I had the same error, but with ZYNQ 7000 (PYNQ board)
regards,
Kevin
Kevin Patino
