thngttr
Vring address
Hello! I've been looking into OpenAMP (UG1186) and the thing that I failed to understand is where from do we get VRING addresses?
The ones that are in zynq example for remote cpu:
Comment to fw_rsc_vdev_vring struct:
 * Note that @da should either contain the device address where
 * the remote remote_proc is expecting the vring, or indicate that
 * dynamically allocation of the vring's device address is supported.
which still doesn't clear it for me.  And i couldn't find any information on this elsewhere.
hbucher
@thngttr Just a location in memory agreed to hold the vring buffers. As stated in page 15,
If you specify it in the resource table, it must be inside the range defined by the DTS reserved-memory section for rproc. It should not overlap its address with the memory nodes in the device tree which are used to load the firmware.
hbucher
thngttr
@hbucher, OK, but this
what was given as an example for dts (page 20).  elf_ddr_0, it seems, is defined for remote firmware, not for remoteproc resources, since it doesn't include Vring addresses.
So, am i supposed to expand elf_ddr_0? Or does linux accept any value for vring addresses given it doesn't overlap with memory nodes in dts?
thngttr
Moved from 2017.1 to 2017.4, compared docs for openamp, and new example device tree for zynq did contain reserved memory definition, which separates remote app memory and rsc_table space from linux ram. Now this makes sense.
