Where can I get echo_test-openamp source code?
I can't find "echo_test-openamp" source code for UltraSCALE+ MPSoC.
I really try to find the code in GitHub, I only find "echo_test" source code.
Where can I find it?
Shin.
Re: Where can I get echo_test-openamp source code?
Hi @cyclone5
You can refer this link for echo test code:https://github.com/Xilinx/open-amp/blob/xilinx-v2018.2/apps/echo_test/echo_test.c
You can refer this link for more info on openamp:https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1186-zynq-openamp-gsg.pdf
Thanks & regards
Aravind
Hi @cyclone5
Below is the echo test application source
https://github.com/OpenAMP/open-amp/blob/master/apps/examples/echo/rpmsg-echo.c
Kranthi
Best Regards
Kranthi
Hi.
Thanks for your reply, but I have echo_test.c code already. I need source of echo_test-openamp in linux test application.
I think the echo_test-openamp have a vring test code. I want to know how to control vring in petalinux.
I need more your help.
Regards.
Shin.
