Visitor nwaters
Where do I find or generate a *.bsp file?
I am trying to go through the steps in UG1186 to build the example Linux/Bare Metal Echo Test. When creating the Peta Linux project you have so specify a path to the BSP that was previously generated. Where do I find that file? I have search within the BSP project folder in my XSDK workspace and I can't find a *.bsp file. I looked in the makefile and I can't see any rule that would create it.
This seems to be the same question, but the accepted answer doesn't answer the question:
https://forums.xilinx.com/t5/OpenAMP/Openamp-library/m-p/691196/highlight/true#M92
Re: Where do I find or generate a *.bsp file?
Which version of the document are you using? Could you please provide page number/step in the document?
Visitor nwaters
I am using PetaLinux Tools/Vivado/SDK versions 2018.2. I am running them on Ubuntu 16.04.3. I am trying to build the echo test example on a Rev D. Zedboard.
I am at step 1 under the headings "Building Linux Application that uses RPMsg in kernel space" "Setting up PetaLinux with OpenAMP", I've copied the text for the step below:
Create the PetaLinux master project in a suitable directory without any spaces. In this guide it is named <plnx-proj-root>:
$ petalinux-create -t project -s <PATH_TO_PETALINUX_ZYNQMP_PROJECT_BSP>
All petalinux bsps can be found here
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
You will need to download it and point to it to create your petalinux project. Please also look at UG1144
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
<plnx-proj-root> is the root directory where your petalinux project is created
Visitor nwaters
OK. So just to reiterate in case someone else gets confused like I did: The BSP used for PetaLinux is entirely different than the BSP project that was previously created in XSDK for the Bare Metal processor.
Yes,
The petalinux bsp is for your master processor which runs linux (A53 in case of ZynqMP or A9-0 in case of Zynq)
For your remote processor (the bsp can be standalone/freertos) created in SDK
