Xilinx AMP Multicore Programming -OpenAMP
I am looking for Xilinx Asymmetric Multi core Programming(AMP) support for Zc702/ZC706 EVAL board. Wanted know how to create Master and Remote Application(Firmware) using OpenAMP on Vivado SDK 2017.2/ Petalinux 2017.2.
Gone through the examples such as OpenAMP Echo test and Matrix multiplication(UG 1186). But I wanted to know how to create our own  AMP Master and Remote Application . Core 0 should run Linux and Core 1 should run Baremental.--Thanks in advance
Re: Xilinx AMP Multicore Programming -OpenAMP
 Use the example application as a starting point for building your own application.
You can also look at the 2018.3 user guide, page 23, How to write a simple OpenAMP application
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1186-zynq-openamp-gsg.pdf
