cortex-R5 ipi address in system-user.dtsi file
Hi.
I have a question about ipi address.
I knew that Cortex R0 ipi address begin is 0xFF310000 ans R1 ipi address begin is 0xFF320000.
but example dtsi file (openamp-overlay.dtsi) has another IPI address, 0xFF34000000. I know  that 0xFF3400000 is PL0 IPI address.
I try to switch 0xFF310000 to 0xFF340000,  openAMP examples are not working.
What is mean 0xFF3400000 IPI address in dtsi file?
Shin.
Re: cortex-R5 ipi address in system-user.dtsi file
0xFF3400000 IPI (i.e. PL0 IPI) is used for APU since the default APU IPI is used by PMUFW and ATF.
