Observer allenguo
failed to build r5 echo test firmware with SDK
I am trying to reproduce echo_test with source code following the steps in ug1186 v2018.2. I am using latest ZCU102 board. All my tools are v2018.2. I was able to create my own openamp Linux system, boot from SD card. From it, I was able to run echo_test successfully with petalinux-generated firmware/applications.
Then I built my own echo_test firmware for R5 following the instruction in UG1186 pg.28 "Building OpenAMP application for RPU Firmware". The build was successful.
However when I try to use my firmware instead of demo firmware in /lib/firmware, I got the error messages.
root@xilinx-zcu102-2018_2:~/echotest/Debug# echo ./echotest.elf > /sys/class/remoteproc/remoteproc0/firmware
root@xilinx-zcu102-2018_2:~/echotest/Debug# echo start > /sys/class/remoteproc/remoteproc0/state
-sh: echo: write error: No such file or directory
Comparing /lib/firmware/image_echo_test with my echotest.elf, they both have identical source code. However, it seems one is hard-float and one is soft-float.
root@xilinx-zcu102-2018_2:~/echotest/Debug# readelf ./echotest.elf -h
ELF Header:
Magic: 7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
Class: ELF32
Data: 2's complement, little endian
Version: 1 (current)
OS/ABI: UNIX - System V
ABI Version: 0
Type: EXEC (Executable file)
Machine: ARM
Version: 0x1
Entry point address: 0x0
Start of program headers: 52 (bytes into file)
Start of section headers: 768872 (bytes into file)
Flags: 0x5000400, Version5 EABI, hard-float ABI
Size of this header: 52 (bytes)
Size of program headers: 32 (bytes)
Number of program headers: 3
Size of section headers: 40 (bytes)
Number of section headers: 29
Section header string table index: 28
root@xilinx-zcu102-2018_2:~/echotest/Debug# readelf /lib/firmware/image_echo_test -h
ELF Header:
Class: ELF32
ABI Version: 0
Machine: ARM
Version: 0x1
Start of section headers: 801428 (bytes into file)
Flags: 0x5000200, Version5 EABI, soft-float ABI
Number of section headers: 28
Section header string table index: 27
Can you let me know how to build a working firmware?
Thank you,
Allen
Observer allenguo
Re: failed to build r5 echo test firmware with SDK
Hi jovitac,
Thank you for replying. I figured it out. Basically, all I need to do is to copy my cortex-r5 binary file to /lib/firmware, then use
echo "file name" > /sys/class/remoteproc/remoteproc0/firmware
It works nicely.
Thanks for help,
Allen
Hi Allen,
Could you please share the recipe for your application?
Observer allenguo
Hi jovitac,
It works nicely.
Thanks for help,
Allen
