how to use OpenAMP, IPI interrupt together.
HI~
I use ZCU104 MP SoC Board.
I designed IPC Like this
* OpenAMP
APU <-> RPU0
APU <-> RPU1
And RPU use IPI interrupt each other.
*IPI
RPU0 <-> RPU1
When I initialized IPI interrupt in RPU0, I use 0x0300 mask for XIpiPsu_InterruptEnable().
but working is not good.
Working is well OpenAMP only, working is well IPI only too. but using those combination IPC system is not working,
I think doesn't shared Interrupt. OpenAMP and IPI. So. I will find another way.
When I use OpenAMP APU and both RPUs, I wonder how to message send/receive between RPUs.
Please Let me know this.
Regards.
Shin.
Re: how to use OpenAMP, IPI interrupt together.
Hi Shin,
I'm not exactly sure what you are trying to do. Do you have application running on both RPU-0 and RPU-1 and linux running on APU? Have you tried the example we have on wiki to run OpenAMP on 2 RPU slaves
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841990/OpenAMP+2018.2
I would recommend reading the IPI Interrupts and Message Buffers section in Chapter 13 of UG1085.
https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf
Can you also try the baremetal example that we have? You can modify this to send IPI from RPU0 to RPU1. Make sure this works.
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/ipipsu/examples/xipipsu_self_test_example.c
HI.
Thanks for your reply.
I try to OpenAMP APU and RPUs and to use IPI  for to send/receive between RPUs.
When I initialize OpenAMP, can't send/receive IPI message in RPUs.
I think why is OpenAMP and IPI shared same Interrupt. so When I use OpenAMP (Linux master, RPUs slave), I want to new how to send/recieve between RPUs another way.
I means
APU  ->(OpenAMP) -> RPU0 ->(Something Signal) -> RPU1 ->(OpenAMP) -> APU.
Help me, I need more your information.
Regards.
Shin.
