Participant thngttr
interrupt routing
Hi!
I had linux on cpu0 and baremetal on cpu1 and they were successfully communicating via remoteproc.
Then i added uart0 interrupt handling.
After few [receive interrupt -> send bytes] iterations baremetal application either goes to Xil_UndefinedExceptionHandler or stops receiving interrupts at all.
Without linux, uart0 app works fine.
Here is device tree (system-user.dtsi):
    reserved-memory {
        #address-cells = <1>;
        #size-cells = <1>;
        ranges;
        rproc_0_reserved: rproc@100000 {
            no-map;
            reg =  <0x100000 0x16F00000>;
    amba {
        elf_ddr_0: ddr@0 {
            compatible = "mmio-sram";
            reg = <0x100000 0x15F00000>;
    remoteproc0: remoteproc@0 {
        compatible = "xlnx,zynq_remoteproc";
        firmware = "firmware";
        vring0 = <15>;
        vring1 = <14>;
        srams = <&elf_ddr_0>;
		interrupt-parent = <&intc>;
		interrupts = <0 27 4>; //uart0 interrupt routing!
    chosen {
		bootargs = "clk_ignore_unused";
&uart0 {
	compatible="invalid";
kernel base address - 0x18000000
netboot offset - 0x19000000
rsc_table.c:
RING_TX - 0x16000000
RING_RX - 0x16004000
{RSC_RPROC_MEM, 0x16000000, 0x16000000, 0x100000, 0}
lscript.ld:
ddr base - 0x00100000
size - 0x15F00000
Is there something else that needs to be done to route interrupt to cpu1? (XScuGic_InterruptMaptoCpu is used)
Can it be memory related error? Any hint would be really welcome.
Participant thngttr
Re: interrupt routing
Well, problem was not related to linux or OpenAMP at all, but to mere lack of space in stack, or rather, irq_stack sector. Which was only 1024 bytes in size, and therefore use of heavy sprintf caused stack corruption.
lscript fix:
_IRQ_STACK_SIZE = DEFINED(_IRQ_STACK_SIZE) ? _IRQ_STACK_SIZE : 1024 0x2000
Which version of the tools are you on? Is this on Zynq or ZynqUltrascale+?
Participant thngttr
Zynq 7000 and Vivado/Petalinux 2017.4
Participant thngttr
Don't know if it means anything (because looking at the code (1 and 2) - it shouldn't) every time at first interrupt linux gives the following output:
C_Users_engineer18.VREMENA_AppData_Local_Packages_Microsoft.SkypeApp_kzf8qxf38zg5c_LocalState_400ced25-4444-4520-8084-e675f70e8052.PNG
Usually it's IRQ 49, which corresponds with remoteproc-uart0 interrupt (cat /proc/interrupts):
But sometimes it's 26 - which is uart1. And 48 doesn't correspond to anything.
Participant thngttr
So, I've debugged the program by removing peaces of code and looking what corrupts the flow of the program. Trouble function turned out to be sprintf - it was corrupting the stack:
main() calls freemove() and then interrupt occurs and handler calls sprintf(), during which stack loses pointer to main(), which causes program to fail.
sprintf() is replacable, of course, but reason why this happens is still unclear. Memory in the stack should be enough to hold this amount of information.
Participant thngttr
Removed linux from the system - now it's simple baremetal app on cpu0 with interrupts on buttons. Interrupt handler calls sprintf. Same picture as before (stack loses main() and cannot return to it).
P.S. Or it was. After several power resets sprintf stopped breaking stack. This needs more testing.
Participant thngttr
lscript fix:
