libmetal demo simultaneously on R5_0 and R5_1: problems
Hi everyone!
I hope this branch is the most appropriate for libmetal - related question.
I have a problem starting application on second R5_1 core while I run some application in the first R5_0 core. I used libmetal demo application from UG1186 as example application for R5.
Problem: libmetal demo configures only one /sys/class/remoteproc/remoteproc0
So I can start one demo application on the first core R5_0 and do not have possibility to start the demo application on the second R5_1 core, because I need /sys/class/remoteproc/remoteproc1 for this.
What I attempted to resolve: Updated Device Tree adding components for the second core.
I took example from: https://github.com/Xilinx/meta-openamp/blob/rel-v2017.4/recipes-bsp/device-tree/files/zynqmp/openamp-overlay-split.dtsi
Problem: The updated Device Tree did not help. Petalinux starts only remoteproc0, and does not create remoteproc1.
What have I missed? Thank you.
My environment: Zynq UltraScale++, Petalinux 2017.4, Vivado/SDK 2018.1
I attached my system-user.dtsi to this post
Here the exstract of the system-user.dtsi related to libmetal:
	reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		rproc_0_reserved: rproc@3ed000000 {
		no-map;
		reg = <0x0 0x3ed00000 0x0 0x2000000>;
	amba {
	/* Shared memory */
		shm0: shm@0 {
		compatible = "shm_uio";
		reg = <0x0 0x3ed80000 0x0 0x1000000>;
	/* IPI device */
		ipi_amp: ipi@ff340000 {
		compatible = "ipi_uio";
		reg = <0x0 0xff340000 0x0 0x1000>;
		interrupt-parent = <&gic>;
		interrupts = <0 29 4>;
	/* firmware memory nodes */
		r5_0_tcm_a: tcm@ffe00000 {
			compatible = "mmio-sram";
			reg = <0x0 0xFFE00000 0x0 0x10000>;
			pd-handle = <&pd_tcm_0_a>;
		r5_0_tcm_b: tcm@ffe20000 {
			reg = <0x0 0xFFE20000 0x0 0x10000>;
			pd-handle = <&pd_tcm_0_b>;
		r5_1_tcm_a: tcm@ffe90000 {
			reg = <0 0xFFE90000 0x0 0x10000>;
			pd-handle = <&pd_tcm_1_a>;
		r5_1_tcm_b: tcm@ffe92000 {
			reg = <0 0xFFEB0000 0x0 0x10000>;
			pd-handle = <&pd_tcm_1_b>;
		elf_ddr_0: ddr@3ed00000 {
			reg = <0x0 0x3ed00000 0x0 0x100000>;
		elf_ddr_1: ddr@3ed40000 {
			reg = <0 0x3ed40000 0x0 0x40000>;
		test_r5_0: zynqmp_r5_rproc@0 {
			compatible = "xlnx,zynqmp-r5-remoteproc-1.0";
			reg = <0x0 0xff9a0100 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>;
			reg-names = "rpu_base", "ipi", "rpu_glbl_base";
			dma-ranges;
			core_conf = "split0";
			srams = <&r5_0_tcm_a &r5_0_tcm_b &elf_ddr_0>;
			pd-handle = <&pd_r5_0>;
		test_r5_1: zynqmp_r5_rproc@1 {
			reg =<0x0 0xff9a0200 0 0x100>, <0x0 0xff340000 0 0x100>, <0x0 0xff9a0000 0 0x100>;
			dma-ranges;
			core_conf = "split1";
			srams = <&r5_1_tcm_a &r5_1_tcm_b &elf_ddr_1>;
			pd-handle = <&pd_r5_1>;
	power-domains {
		pd_r5_0: pd_r5_0 {
			#power-domain-cells = <0x0>;
			pd-id = <0x7>;
		pd_r5_1: pd_r5_1 {
			pd-id = <0x8>;
		pd_tcm_0_a: pd_tcm_0_a {
			pd-id = <0xf>;
		pd_tcm_0_b: pd_tcm_0_b {
			pd-id = <0x10>;
		pd_tcm_1_a: pd_tcm_1_a {
			pd-id = <0x11>;
		pd_tcm_1_b: pd_tcm_1_b {
			pd-id = <0x12>;
Re: libmetal demo simultaneously on R5_0 and R5_1: problems
Please use same versions of Petalinux, Vivado/SDK. I would suggest building a Petalinux project for 2018.1
In order to run the Libmetal application on both RPU cores simultaneously, you will need
1. Linux application (say linux-app-r5-0) and a r5-0 firmware application
2. Linux application (say linux-app-r5-1) and a r5-1 firmware application
3. This requires you to have 2 shared memory, ipi and ttc nodes defined in the device-tree for each of the rpu firmware applications
4. Your linux application, that talks to R5-1 must also be modified. The IPI mask will be change in this case
#define IPI_MASK        0x200 /* IPI mask for kick from RPU. */
Make sure you have no overlapping addresses.
Attached is an example system-user.dtsi. Make sure you make the necessary changes in the linux and the rpu applications as well.
Dear jovitac,
Thank you very much for the explanation and detailed example system-user.dtsi !
May I ask you to confirm or comment the boundaries of shm@ and shm@1 ?
The example system-user.dtsi you kindly provided contains the following boundaries for the above shared memory regions:
shm0: shm@0
shm1: shm@1
reg = <0x0 0x3fd90000 0x0 0x1000000>;
This means that shm@1 ends at 0x3fd9 0000 + 0x100 0000 = 0x40d9 0000
This is beyond of the declared reserved memory region which ends at 0x3ed0 0000 + 0x200 0000 = 0x40d0 0000:
Does this mean that shm@1 in the proposed system-user.dtsi lays partially outside of the reserved memory? Is it what we suppose to do or shall we adjust either shm@1 or reserved memory to fit?
Thank you.
Yes. Please change either the shared memory or the reserved memory region.
