Visitor raha_2181
memory allocation failed in CPU#1 after reset -- AMP -- ZYNQ SDK
Hi everybody,
I use VIVADO 2015.1 and SDK 2015.1, on Microzed with zynq7010 with dualcore ARM and in a part of code I reset CPU#1 from CPU#0.
After reset, CPU#1 fails to allocate memory with new or malloc functions. When I changed the memory allocation to static buffers the problem solved. However, based on the code which is used NEON library I cannot change all memory allocations. Does anyone have any idea why this happens?
I use the reset instruction in xapp1079 and the reset works fine except for the memory allocation after reset.
Thanks for your help in advance.
--raha
