multiple tasks in echo test SDK 2018.3
Hi all,
The OpenAMP demos have a big change in SDK 2018.3 compare to previous. It makes my app which has multiple/parallel tasks stop working, because the poll function requests the core to sleep (https://github.com/Xilinx/embeddedsw/blob/release-2018.3/lib/sw_apps/openamp_echo_test/src/machine/zynqmp_r5/platform_info.c#L392). My application is based on FreeRTOS.
So, do you have any idea to add more tasks into echo test example? Thank you.
Re: multiple tasks in echo test SDK 2018.3
I found it myself.
The echo_test (same with other OpenAMP demos) will disable the FreeRTOS task scheduler because of re-initialize GIC (code here: https://github.com/Xilinx/embeddedsw/blob/release-2018.3/lib/sw_apps/openamp_echo_test/src/system/freertos/machine/zynqmp_r5/helper.c#L23). So the FreeRTOS task scheduler will not work. Solution is update the app_gic_initialize() function to make it compatible with FreeRTOS task scheduler GIC setup.
I found it myself.
Observer shinya
I have trouble with this problem.
Could you tell me how to update the app_gic_initialize() function to make compatible with FreeRTOS task scheduler GIC setup?
Hi @shinya,
You can replace this code https://github.com/Xilinx/embeddedsw/blob/release-2018.3/lib/sw_apps/openamp_echo_test/src/system/freertos/machine/zynqmp_r5/helper.c#L20-L77 by below:
extern XScuGic xInterruptController;
/* Interrupt Controller setup */
static int app_gic_initialize(void)
	/* Connect Interrupt ID with ISR */
	XScuGic_Connect(&xInterruptController, IPI_IRQ_VECT_ID,
			(Xil_ExceptionHandler)metal_irq_isr,
			(void *)IPI_IRQ_VECT_ID);
	return 0;
Observer shinya
Hi, @nvl1109.
Thank you for your quick response. I can solve this problem!
