open_amp library?
Hi, all
    if I want to use open amp deploy my board, should I download open_amp_master through link https://github.com/OpenAMP/open-amp, and compile it? because when I create a bare-metal project and add a parameter –DUNDEFINE_FILE_OPS and -DUSE_AMP=1, the console prompt an error :ld: cannot find -lopen_amp
    can you give me some hints? Thank you very much
    Tom
Re: open_amp library?
Flags -DUNDEFINE_FILE_OPS and -DUSE_AMP are not targeting the OpenAMP library but the Xilinx library (see Xilinx SDK).
Make sure you check UG1186 to understand when/how to set this flags, they are not needed to run the basic echo-test demo for example.
You can recompile the OpenAMP library from the github project if needed; if you use a Xilinx board, you may want to start with the SDK provided libraries as a starting point.
If your board is a Xilinx board, you should consider this...
https://github.com/Xilinx/open-amp
And not this...
There is a difference.
