Observer ajcurtis84
question regarding lscript.ld and ps7_ram regions
When I look at the linker script generated for an application I see:
MEMORY
ps7_ddr_0_S_AXI_BASEADDR : ORIGIN = 0x00100000, LENGTH = 0x08000000
ps7_ram_0_S_AXI_BASEADDR : ORIGIN = 0x00000000, LENGTH = 0x00030000
ps7_ram_1_S_AXI_BASEADDR : ORIGIN = 0xFFFF0000, LENGTH = 0x0000FE00
This is the default memory configuration of the Zynq7000. However when you run U-Boot, it changes the memory configuration to:
DDR ORIGIN = 0x00000000, LENGTH = 0x08000000
OCM ORIGIN = 0xFFFC0000, LENGTH = 0x00040000
Is correct?
Note: The map file confirms the memory map.
Memory Configuration
Name Origin Length Attributes
ps7_ddr_0_S_AXI_BASEADDR 0x00100000 0x08000000
ps7_qspi_linear_0_S_AXI_BASEADDR 0xfc000000 0x01000000
ps7_ram_0_S_AXI_BASEADDR 0x00000000 0x00030000
ps7_ram_1_S_AXI_BASEADDR 0xffff0000 0x0000fe00
*default* 0x00000000 0xffffffff
Linker script and memory map
LOAD /opt/Xilinx/SDK/2015.4/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-eabi/4.9.2/crti.o
LOAD /opt/Xilinx/SDK/2015.4/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-eabi/4.9.2/crtbegin.o
0x00002000 _STACK_SIZE = DEFINED (_STACK_SIZE)?_STACK_SIZE:0x2000
0x00004000 _HEAP_SIZE = DEFINED (_HEAP_SIZE)?_HEAP_SIZE:0x4000
0x00000400 _ABORT_STACK_SIZE = DEFINED (_ABORT_STACK_SIZE)?_ABORT_STACK_SIZE:0x400
0x00000800 _SUPERVISOR_STACK_SIZE = DEFINED (_SUPERVISOR_STACK_SIZE)?_SUPERVISOR_STACK_SIZE:0x800
0x00001000 _IRQ_STACK_SIZE = DEFINED (_IRQ_STACK_SIZE)?_IRQ_STACK_SIZE:0x1000
0x00000400 _FIQ_STACK_SIZE = DEFINED (_FIQ_STACK_SIZE)?_FIQ_STACK_SIZE:0x400
0x00000400 _UNDEF_STACK_SIZE = DEFINED (_UNDEF_STACK_SIZE)?_UNDEF_STACK_SIZE:0x400
.text 0x00100000 0x51d4c
0x00000000 _binary_firmware1_start = 0x0
0x00000000 _binary_firmware1_end = 0x0
0x00000000 _binary_firmware2_start = 0x0
0x00000000 _binary_firmware2_end = 0x0
*(.vectors)
.vectors 0x00100000 0x11c /home/allen/work/LEA/standalone_bsp_1/standalone_bsp_1/ps7_cortexa9_1/lib/libxil.a(asm_vectors.o)
0x00100000 _vector_table
Tags (4)
