Participant kvkhekale
"Failed to open rpmsg0 file /dev/rpmsg0" on petalinux 2017.4 openamp
Hello all,
We are trying to run Openamp project on petalinux 2017.4 on picozed board.
As shown in the logs, demo application image_echo_test boots  and remoteproc0 also starts.
But, as we give command of echo_test start, we are getting error message as "Failed to open rpmsg file /dev/rpmsg0."
the device tree settings for system-user.dtsi are done according to the settings UG1is mail. 186.
Please guide regarding this matter.
I have attached error logs with this mail
Re: "Failed to open rpmsg0 file /dev/rpmsg0" on petalinux 2017.4 openamp
I don't see any error logs or device-tree attached. Please attach both.
I have attached error logs as an attachment.
Attaching the device tree as follows:
Please let me know if you need any more information regarding this
