johnrp123
remoteproc start fails with error -2
Trying to load the FreeRTOS demo in the 2017.1 SDK.
After fixing the broken source files in the Xilinx SDK product included project, I was able to build the .elf file.
I can run other demos that I build for the ZCU102 for the R5 to run, echo, mult, etc...
When I build the FreeRTOS example project and try to load and run the .elf, I get the following...
[1234...] remoteproc remoteproc0: Direct firmware load for RTOSDemo.elf failed with error -2
[1234...] remoteproc remoteproc0: request_firmware failed: -2
[1234...] remoteproc remoteproc0:Boot failed: -2
-sh: echo: write error: No such file or directory
This is the RTOS Demo from the FreeRTOS site contained in their version 9 distribution.
I tried to build the FreeRTOS demos included in the Xilinx 2017.1 SDK, however that is a basket case
and since I do not work for them, I will let it sit in the pond where it cancontinue to... grow algae I suppose.
The file is there btw so something more sinister is going on.
jovitac
Maybe just something you're missing in the dts or maybe your .bb for your petalinux application?
Log of a free-rtos echo-test demo on a zcu102
deville
Just for the record and for the sake of other users who might be stuck with this error.
Error -2 is a Linux system error saying: No such file or directory
When you try to load the firmware, the driver looks only in :   /lib/firmware
my 2 cents..
Deville
